More advice
[Closed] More advice
[#2202955]
Could i fit a Sram rear mech and use Shimano shifters?
Posted : 18/11/2010 11:40 pm
I understand that the cable pull leverage ratio is different on the rear between shimano & sram so the they are not compatible. The front mech / shifter is ok to mix as the cable pull ratio is the same.
Posted : 18/11/2010 11:50 pm
No with 9 speed stuff, yes with the new 10 speed from what I've seen. Front mechs are all fine, it's only rear where there's an issue.
Hi, thanks for your replies, i'll be knocking that idea on the head then.
Steveo
Posted : 19/11/2010 12:05 am
