Hi,
I want to put a Hope Mono M4 caliper (8) on the back end of my Cotic Soul.
When it's attached, there is very little over lap with the disc. Do I just need a bigger disc? The current disc is a 165mm diameter, would a 180(?) do the job or is some sort of adaptor required?
Thanks
Matt
Posted : 07/03/2010 9:02 pm
I assume IS mount? My pre mono m4 calipers are no. 8 and fit a 180 disc. Is mount calipers are sized for discs - no adaptors needed as the calipers come in different sizes for different sized discs
Posted : 07/03/2010 9:10 pm
Looks like you have the wrong sized disc or caliper. According to [url= http://www.hopetech.com/technical/tab_fitt.htm ]Hope[/url] the No8 on the rear is for a 185mm rotor.
Posted : 08/03/2010 4:25 pm
