Hi, just wondering what the weight of a teocali comp 09 is?
I read someone before that with the standard parts listed in the link below, it came in around 33lbs.
What do you guys consider to be a good weight for a full susser? I'm tempted to put some parts from my hardtail on it to see if I can make it a bit light because I do really enjoy riding it but it is a little heavy sometimes.
I had an 09 teocali super, no way was it 33lbs. I've just built a Nicolai frame with all the parts from the teocali and that weighs 32lbs with a heavier frame.
Stand on bathroom scales.
Write down your weight (a).
Pick up bike.
Write down this weight (b).
Do this mathematical equation.
b-a= weight of your bike
iolo, I never thought about using the bathroom scales haha
Mine is set up with revs, hope/Superstar wheels, and old LX/ Deore kit, so not super light but probably lighter than your stock bike and it is great. It was not as light as an Yeti 575, but not far off a 5 Spot when comparing with mates. I am never first up a climb regardless of bike, but it is a lot of fun coming down and it certainly doesn't hinder me!
I'm tempted to put my 130mm revelations on it with my stans crest tubeless wheelset. I will see haha
Sub 150mm? Under 30 without trying 26-28 is what I'm aiming for
160/170mm should be good to sub 32 and still be robust.
My 160 front/140 rear comes in at about 28lb
Did you ever fit the offset bushes to your teocali woody? And did they alter the head angle as expected. 🙂
I didn't - bought the kit but never got round to fitting them. Still got the kit though if you fancy buying it? 😉
I might be buying a cheap 06 teocali frameset for a bit of a project. If it happens I will definitely be interested in them. I'll ley you know woody.
Also just one more question. Does the Teocali Super frame weigh less than the Comp? or is it literally just a different colour? haha
