Mongoose Teocali Co...
[Closed] Mongoose Teocali Comp Help
[#4792466]
Anyone an owner and know what headset it takes, or anyone recommend one?
All I can find is it's a zero stack headset.
Posted : 24/01/2013 5:20 pm
Mine had one of these in it (2009 Elite)
http://www.fullspeedahead.com/products/281/ZS-4
Posted : 24/01/2013 5:23 pm
Cheers mate, problem i've got now is those ones are all discontinued!
Posted : 24/01/2013 5:33 pm
Not an owner but zerostack headsets are normally 44mm, there is now quite a selection of zerostack, semi intigrated, 44mm, integral headsets on the market.
How much do you want to spend?
£35 - http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=51070
£72 - http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=18084
Posted : 24/01/2013 5:34 pm
IIRC it's the same as my GT, which used one of [url= http://superstar.tibolts.co.uk/product_info.php?cPath=25&products_id=114 ]these[/url] for about 18 months no problem before it got replaced with a Works Components Angleset.
I know Superstar don't have a great rep for bearings but the ones I had in this worked fine.
Posted : 24/01/2013 5:41 pm
My project from the beginning is to not spend more than £20 on any part and see what I end up with at the end of the build.
Tis might help identify what you need - [url= http://www.bicycleheadsets.com/uploads/SHIS_PR_TECH_DOCUMENT_v2__3_.pdf ]SHIS Data Sheet[/url]
Posted : 24/01/2013 5:50 pm
Do you need the complete headset? You can buy bearing kits which would make it cheaper
http://superstar.tibolts.co.uk/product_info.php?cPath=61&products_id=282
Posted : 24/01/2013 5:54 pm
I can get down to £27
http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=15888
Whilst buying bearings will work out the cheapest option for getting the headset working be aware that not all zerostack headsets use 36/45 degree angular contact bearings. You may be able to get the spec of the bearing off the current ones.
Posted : 24/01/2013 6:20 pm
AH! This is really frustrating!
Posted : 24/01/2013 6:35 pm
It's not the headset that's bust, it's the bearings, which ones to buy and the right seals seems impossible.
Posted : 24/01/2013 6:37 pm
