mondraker frames
[Closed] mondraker frames
[#4962153]
as above anyone have any problems with frames cracking?
Posted : 15/03/2013 6:47 am
why????
Dont say that - I just bought one 😕
Posted : 15/03/2013 10:01 am
Had my Factor R just over a year with no problems other than bolts holding bearings in coming loose all the time. Thread lock solved this though.
Posted : 15/03/2013 10:03 am
Owned a few and no cracks - just loose bolts as ric says, and a fair bit of creaking.
Why do you ask?
Posted : 15/03/2013 10:24 am
Have heard of a few with wonky back ends that kept coming loose, but you get that with a percentage of all manufactureres products, think they're pretty good in general.
Posted : 15/03/2013 10:58 am
thats my second foxy cracked in 3 places thats 5 that i know of 3 foxys 1 dune and a factor,seems to be a weakness near the rear shock LBS has been brilliant so should be new frame on the way
Posted : 15/03/2013 11:47 am
Despite me having two cracked Foxy frames I have to say they are lovely bikes to ride
Posted : 15/03/2013 10:42 pm
Bolts coming loose seems to be a recurring thing with Mondrakers
Posted : 15/03/2013 10:54 pm
That's putting it mildly, although I think they actually might have invested in a tub of threadlock now.
novaswift - Good to hear they're sorting you out. There was another Foxy owner on here got a warranty replacement after cracking frame actually.
Posted : 16/03/2013 7:08 pm
chakaping - Member
Yeah, I should have added that it was easily resolved with threadlock - but still a sloppy thing. I've experienced first hand the damage a lost bolt can do to a frame, no fun at all.
Posted : 16/03/2013 7:28 pm
I've had a look at the 2013 foxy frames and they do seem to be designed a bit sturdier where the rear shock is housed. My first foxy was 2010 and then 2012 which both cracked. Three mates Mondrakers have cracked also so hopefully the problems have been ironed out. As I said previously they are brilliant bikes
Posted : 17/03/2013 12:37 pm
My mates foxy cracked around the shock mount, and it went through bearings at an alarming rate. The bearings seemed very small!
Posted : 17/03/2013 1:24 pm
My 2011 Foxy RR has cracked on the drive side in 3 places around the shock area. I've always had issues withe the pivot bolt on that side behind the chainrings working loose. I'm guessing that's is the root cause.
I'm hoping its not bad timing to get a replacement on warranty with 2014 stuff coming out & it all being 650B.
Posted : 17/08/2013 5:58 pm
