You could look at it like this; all the other bike manufacturers in the world are obviously stupid because they didn't go down this route when Gary Fisher tried it.
This is a stupid comparison. Gary Fisher's G2 geometry did the exact opposite of Forward Geometry.
G2 Geometry shortened the cockpit, used a custom offset fork, and longer stem. This essentially kept the wheelbase and the cockpit the same, achieving nothing. Forward Geometry uses a longer TT and a 10mm long stem (effectively) to lengthen the wheelbase while keeping the cockpit the same as non XR models. It's a bold move, but it'll be interesting to see if it works.
The other issue, not really related to the ride quality, but more the ownership of the bike is that G2 geometry relied heavily on a custom fork to keep the wheelbase the same length as before. This meant your choice of fork was very limited, as you could not buy them aftermarket. No room for fork upgrades meant that you basically had to use the fork that Trek told you to. Even if you could, custom forks would be [b]very[/b] expensive. Funny how that didn't last...
I've yet to ride one of these bikes in anger, having only ridden one round a car park myself. However, having spoken to Fabien Barel and Chris Porter at the Exmoor Gravity Rally, they both seem very passionate about it.
As I said, it'll be interesting to see if it takes off, but I'm inclined to believe what the actual experts say, rather than some keyboard warrior.
I still think it's a marketing ploy designed to try to give Mondraker a theoretical edge in the marketplace at a time when the world economy is being squeezed hard
I think you think too much.
that stem looks ridiculous - thats all i can say.
Its a challenging look but I like the concept. Not been on one so I can't say whether or not I'd really like but it sounds like it should work.
Well I do have one in real space, I'm interested in what bwaarp has to say obviously , having rode mine a few times now I haven't noticed any of the issues he's described - perhaps you need a steering damper on the bigger Mondraker as they get slacker to stop it flip flopping due to head angle rather than direct mount stem , and anyway aren't all DH bikes direct mount stems anyway ? I'm sure a lot of them are already pretty much inline already with the head tube.
I'm going to ride mine a lot then make a decision how it rides. Magic heh!? 😆
Nahh they usually have 35 to 50mm offsets. Really interested to have a go on one as it's similar to a Moto setup but I'd be genuinely surprised if the steering is as slow as I'd want it with 750mm bars. I'd rather slacken a bike out to get an increased wheelbase length as the two go hand in hand for their intended use.
I'll jump ship onto a Mondraker if it does work...let us know how you have to change your riding style to suit the bike etc
I've got low rise 770 mm Renthals currently - Weird that Fab and Chris have really high front ends on there's
Which is going against a lot for trends at the moment , but I can't keep up with them! ;]
Matt
Well, I've just spent the weekend riding a demo Foxy XR from P Yates Cycles of Stourport.
Flippin awesome.
First, some background... I've had a 2011 Foxy RR since March last year, set up with 160mm Fox 36 Talas and 70mm/720mm bars. I’ve loved it but unfortunately it cracked a couple months back. Fortunately Mondraker and Silverfish have been totally excellent in sorting the warranty and have provided me with a shiny new replacement frame. This is fortunate, because it was a very short list of frames I’d consider as alternatives to the Mondraker.
However, seeing the new XR setup, with the geometry designed for my preferred (mismatched) suspension setup had piqued my interest, and I determined to try one before building up the replacement frame
Decided the best way to compare was to ride tried and tested trails, so spent both days hammering the same Cannock Chase trails (official, and unofficial) I’ve been riding for years.
Having only ridden once in a month and being on double strength antibiotics, I didn’t expect much in terms of performance, but decided to turn on Strava half way round… and subsequently set 5 Personal Records on a variety of sections.
Sitting on it for the first time – it just felt right. Looks odd, but feels spot on. Does seem a little strange to be able to see so much of the front tyre, and you sense that your weight is in a different position front-to-back… more centred, if anything. The wheelbase is noticeably longer too, and not just from squeezing it onto the bike rack on the car, where it was longer than the last DH bike I put on there some 5 years back.
On some of the corners, I found myself a bit wider on the exit, but soon compensated, and having my weight more over the front gave me the confidence to push through the corners. Some of it may also have been down to the fatter tyres specced as standard on the XR (and the new shiny kashima coated bounce), but it really has been thought out as a complete package, and felt incredibly balanced and stable in the air and at speed.
In short - I will be putting in an order for an XR frame kit, and thinking very carefully about what parts I put on it to closely replicate the full bike spec, but to suit my more modest budget.
Can’t wait.
Can anybody comment on the RR?
Nice mini-review nick. I want to try one even more now.
wors - what do you need to know about the RR, I used to have an R.
How did you find it ? Good all rounder? How about durability etc cheers
The pivot bolts worked loose on loads of them, but normally stop when you apply the loctite that they should've done at the factory. They say this is sorted for 2012, seems better so far.
Foxy is long and low, corners unbelieveably. Only sold mine as I'd gone for a large and the TT was a bit stretched on steeper terrain. The XR would have been the perfect solution!!
QR versions were flexy, maxle rear ones acceptably stiff for me but a bit more stiffness would be nice. Some might still find them too flexy even with maxle I imagine.
Didn't crack mine (had a Dune as well), whereabouts did yours go Nick?
(They have a lifetime frame warranty BTW.)
As chakaping says - they've sorted the pivot bolt issue, by changing the hardware, and also making all bolts accessible from the non-drive side, so even if they do work loose (which they shouldn't) - you have a better chance of doing something about it.
My RR developed hairline cracks from the top rear corners of the cutout in the shock cage (by the mech mount on the drive side). I googled extensively and could only find two other mentions of similar issues - one on a Dune hire bike in the Alps, and on another Foxy somewhere. For the record, I'm 16st ish and allegedly quite hard on bikes, though I maintain I'm smooth like butter, float like a butterfly, etc etc.
I did a fair few Gravity Enduros on it, countless days in the saddle at trail centres, exploring Exmoor and even a couple of Racers Guild timed downhill practice days. So I'd say it was a great all-rounder - aided by the longer travel forks, although by the same token it was maybe a bit compromised in terms of geometry as a result - never quite being as Mondraker intended, switching between 130 and 160, not hitting the 140mm sweet spot they designed it for.
Again, this is why I'm sold on the XR - I think they know what they're doing and having that geometry designed for the 140mm/160mm travel makes it seem even more the perfect all-rounder. On the RR I'd constantly be switching between 130 and 160 for climbs/descents, whereas on the XR, only on the tightest switchback climbs did I switch to the mid setting, partly out of habit.
Bikeradar have just put up a first ride report, giving it 4.5/5:
I've ridden one and it made total sense for enduro style riding, ie gunning it on descents and attacking obstacles. I found it rewarded agressive riding and definitely helped carry speed.
If you want to pootle along on a trail ride, it might not work for you, but if you like to stick it to a bike, it definitely works. To all the doubters, give it a go 🙂
The thing I always wonder about forums and reviews on the internet - even reviews from actual magazine testers- is that they might be able to write a wonderfully deep and meaning article/review/opinion on the ride of any bike part or bicycle but can they actually ride a bike properly- like it was designed to be ridden... or do they just talk a good story
:- On that note I am still loving my Foxy XR - its amazing
This became an even bigger concern of mine when i went to llandegla recently. People on 160mm bikes, leaving the seat up, bottling any remotely more technical obstacle than flat tarmac. That and badly setup suspension causing people to write off a bike as rubbish.
/tangent
The discussion around short stem = faster steering response is quite interesting. I believe i'm right in thinking that wheelbase alone determines turning radius so fork length, top tube length and head angle are just factors which determine wheelbase, along with chain stay length. A longer wheelbase bike needs more steering input to turn (the front wheel)the same corner as a shorter bike.
So stem length doesn't seem to be a factor in this. But it does since your hands and arms need to move the bars, that's the steering input. If your hands are closer to you, and you don't have to reach so far away from your shoulders, you'll have more control over steering inputs. I think that's why you naturally think a shorter stem produces faster steering. It does, but only because it makes it easier for you to generate the same amount of steering input.
I looks to me that Mondraker have lengthened the wheelbase out front but haven't increased the the distance between you and the bars. This is probably why the people who have ridden the bike haven't said the steering is twitchy. What they have achieved, as pointed out on the thread is DH bike wheelbase without a 200mm fork.
Figure we might as well keep this the "Forward" thinking Foxy thread...
[url= http://farm9.staticflickr.com/8226/8462330050_6d941e8551_z.jp g" target="_blank">http://farm9.staticflickr.com/8226/8462330050_6d941e8551_z.jp g"/> [/img][/url]
I bit the bullet in January and ordered the frame - I'd been collecting parts for a month already, and having decided that the frame deserved more than just the worn out bits from my previous Foxy, went for a slew of Hope and XT kit to go with the 2012 36s (bit more beef up front than the standard 2013 34s, and £400-500 cheaper too)
[url= http://farm9.staticflickr.com/8239/8461228259_fd2d19ea39_z.jp g" target="_blank">http://farm9.staticflickr.com/8239/8461228259_fd2d19ea39_z.jp g"/> [/img][/url]
So chuffed with how it's turned out - first ride at the weekend wasn't great in all the slop, trying to avoid premature aging from Cannock sand and grit, but it still shows the same promise of speed I found on the demo bike.
[url= http://farm9.staticflickr.com/8106/8462324802_da78dfc295.jp g" target="_blank">http://farm9.staticflickr.com/8106/8462324802_da78dfc295.jp g"/> [/img][/url]
Thanks to P Yates Cycles of Stourport for the superb build, and yes I will be taking it back soon for a final trim of hose and steerer.
[url= http://farm9.staticflickr.com/8108/8461232913_458ae17e1b_z.jp g" target="_blank">http://farm9.staticflickr.com/8108/8461232913_458ae17e1b_z.jp g"/> [/img][/url]
P.s. if anyone fancies a Foxy without committing to a stubby stem - there's a very nice new R frame still for sale in the classifieds 🙂
And keep your eyes open for Mondraker bringing out a mid season, sub 3 grand Foxy XR build very shortly!
I notice that bwaarp, the arm chair expert, has gone quiet... What a surprise, actually riding the bike gives you a truer feel of it than looking at numbers on a sheet of paper. Who'd have thought it?!
