Hi Guys,
Are all the 2014 alloy Foxy frames the same? I'm sure there may be some difference in the shock but I just wanted to check the lower end ones aren't extra heavy or anything...
Also does anyone have one on here? How is it?
Don't seem to see many about....
Thanks guys!
Iirc the lower spec ones have a qr axle on the rear and the high spec ones have a 12mm
pretty sure it's just the base spec one which has a 135qr axle. The "R" and above are 142x12. That's the only difference as far as I'm aware.
OK guys cheers....that could be an issue then...!
No stealth routing either?
Nope, no stealth on any of the 2014 models.
My other half had the 2014 XR over the summer after demoing the basic spec model at Whinlatter. Built it up himself with Pikes etc. He really enjoyed it on steep, open descents but found anything that was tight and twisty less enjoyable. Climbed surprisingly well but in the end went back to his Soul as he pivots required so much maintenance (they are very exposed by all the mud coming off the rear wheel).
I'm sure you can route the stealth out of the bottom of the seatpost.
