bands are under the can.
drop pressure, remove the bottom oring and pull down.
Posted : 05/07/2017 2:51 pm
Better to remove the shock completely, as has been previously mentioned, you need to remove the O-ring holding the can in place and slide the can downwards in order to fit the spacer.
It's a heck of a lot easier with the shock removed, believe me.
Posted : 05/07/2017 3:11 pm
