Monarch pressure is...
[Closed] Monarch pressure issue.
[#10098989]
Even with 300 psi in it it sags to about 60%.
What has broken?
I used to run rebound at the half way point of late it's been on its second slowest setting.
Ps I'm 13 stone.
Posted : 18/07/2018 8:52 am
I would guess at sucked down, air pressure in the negative chamber is compressing the shock.
I would do an air can serice and inspect (as its free), the air can is going to come off with a bang so be careful.
Posted : 18/07/2018 10:20 am
It's still under warranty is it something they should honour?
Posted : 18/07/2018 10:25 am
Could be a compression circuit failure if its sagging that much.
If its under warranty I'd be sending it back in
Posted : 18/07/2018 10:30 am
