Monarch Air Sleeve ...
[Closed] Monarch Air Sleeve alignment?
[#10651259]
When replacing the sleeve after an air can service the service manual says that the sleeve has to be rotated into the correct orientation. TBH I've never noticed that before and have maybe just been lucky, but yesterday I must have got it wrong as the shock was leaking air. Removed and refitted and everything is now ok.
What is the correct alignment? I can't see anything on my sleeve to use as a guide other than the decals (in which case, why does it matter)?
Posted : 03/06/2019 10:41 am
DebonAir TM Air Can only: Reinstall the high volume sleeve
so that the indentation on the sleeve aligns with the middle
o-ring gland
Ah, now I realise this isn't talking about 360 degree rotation... It is only about aethetics after all!
Posted : 03/06/2019 10:50 am
