Mobi Washer
[Closed] Mobi Washer
[#9978513]
Trying to source a new spray nozzle for my mobi washer as its got a crack in it. Looked on crc but none available.
Also my other half has lobbed the charger when clearing the kitchen for our house move. Need to source a replacement.
Posted : 09/05/2018 11:37 am
Bikediscount.DE seemed to be the cheapest - who didnt subsequently want 15 quid to post the lever....
my lever also cracked - wasnt chuffed.
Posted : 09/05/2018 12:22 pm
Aren't the spray guns standard hose fitment? Sure mine is so any cheap spraygun should be fine.
Re replacement charger I'll check the specs on mine when i get home, should be cheap to replace with a third party one - i ended up with one of their torch come battery things as i couldn't find the specs nor a standalone charger for sale and that was the cheapest source of replacement.
Posted : 09/05/2018 1:09 pm
Nah they ain't standard ones.
The connection is smaller and the hose is smaller.
You can get an adaptor for the hose to fit standard hoZelock connector but you will use more water.
I like the shower attachment for mine as I use it as a post ride shower when I'm away in the van
Posted : 09/05/2018 1:29 pm
CPC Farnell sell spares for the Sealey PW1712 pressure washer which is rhe same thing.
They're usually fairly cheap and have decent stock.
Posted : 09/05/2018 1:49 pm
owe that man a pint .... cheaper than chips for the guns.... might even order a spare at that price.
they Have the chargers too .
Posted : 09/05/2018 2:16 pm
Two pints for that man! New nozzle on the way...
Posted : 09/05/2018 6:20 pm
Cheers notmyrealname. Ordered nozzle, just waiting for the charger to come back in stock.
Posted : 09/05/2018 7:33 pm
I'm waiting for the Charger as well.
I've had 4 mobis in 3 years (warrantly replacement due to leaking) and the chargers have always failed in less than a year.
It doesn't render the mobi completely useless as you can still use your car charger, but it's hassle.
Common symptoms are when you plug it in to charge it up, it's showing the Green light rather than the Red.
Green means Fully Charged.
Red means Charging.
Obviously it is not fully charged as the battery doesn't work.
Posted : 09/05/2018 7:40 pm
