People!Does anyone out there have any idea about fixing the trigger mechanism on a Mobi pressure washer gun.Whats happenning is,it doesn't shut off when you release it,you have to manually turn it off at the main switch.Anyone had the same problem??
yes mine has done the same for at least a year, cant get a new one for it as they dont exist anymore as far as im aware. i just put up with it as it is. I did plan on buying a nomad gun and connecting that somehow using theirs and mobis fittings, but never got around to it
it looks as though you can open the gun at the bottom, but ive tried and couldnt get it open. thought i was going to break it so stopped
... said no Pioneer ever. Pfft, try harder.
You can open the gun and replace the broken spring inside. Don't open the bottom but instead unscrew and remove the brass spraying nozzle. Under that you will find a brass rod with a hole through the end. Put a screw driver through the hole and unscrew this brass rod (it will be TIGHT). Inside you'll find the spring that needs replacing.
can get replacement parts from Sealy, same company but make a detergent gun for them too
