Mobi pressure washe...
[Closed] Mobi pressure washer gun .
[#9931089]
Mine is leaking like a sive , anyone replaced thiers with a better built one ?
Posted : 07/04/2018 3:06 pm
When mine did that it was just a missing O ring where it attaches to the hose. Worth a look.
Posted : 07/04/2018 4:47 pm
mine is doing this also because I left it out in the cold. I'm going to try b&q to see whether they have one which will work with the hose
Posted : 07/04/2018 6:10 pm
No its spraying out of the actual gun , more water coming out of the plastic bits than the nozzle .
Posted : 07/04/2018 7:00 pm
Mine* did this after I dropped it on the floor once too many times. I took it to bits completely, and then superglued all the cracks shut. This involved a bit of controlled destruction, I had to peel the rubber overmoulding off to get at the cracked bits, but that's not a vital part, I just binned it. Works fine again now.
* Technically it's an Aqua2Go, but the gun is the same.
Posted : 07/04/2018 7:47 pm
I think I've got a spare in the garage. Free for postage.
Posted : 07/04/2018 8:18 pm
