Mk1 vs Mk2 Sram Gui...
[Closed] Mk1 vs Mk2 Sram Guide bleed kits?
[#9347453]
Hi there STW - I previously had mk1 Sram guide rs' and have the relevant epic solutions bleed kit for that.
Now have the mk2 guide R and one lever is a bit firmer / bites a bit further from the handlebar than the other. So I want to bleed the one hat bites closer to the handlebar to get it firmer / biting earlier.
I know the calliper has changed and is supposed to be much easier to bleed than the mk1 (although I didn't find it difficult to bleed anyway), does it require a different bleed kit?
Posted : 25/05/2017 11:55 am
If ti's got the 'Bleeding Edge' port it will need a different one, yup. Is the bleed port an allen key affair?
Posted : 25/05/2017 12:11 pm
I don't think it's got a screw to undo like the last one - bit of research suggests I need a bleeding edge tool.
Posted : 25/05/2017 1:43 pm
