MJ-872 which batter...
[Closed] MJ-872 which battery pack?
[#3385202]
There seem to be 2 types on offer
One in an aluminium enclosure and one in a black plastic enclosure
http://www.ebay.co.uk/itm/Magicshine-MJ-872-1600-Lumens-LED-Bike-light-/180758642497?pt=UK_SportsLeisure_Cycling_Bike_Lights&hash=item2a160dff41#ht_2502wt_1398
Not bothered about voltage display, I care about it being waterproof and if one version performs better than the other.
Opinions?
thanks
Posted : 24/11/2011 12:19 am
If you're willing to spend more on a better battery there are a range of options on the link below for the Open light Systems batteries:
http://www.magicshineuk.co.uk/products/Front-Bike-Light-Magicshine-MJ-872-LSET
Not sure how they compare to the others but might be worth a look.
Posted : 24/11/2011 12:24 am
Give Smudge on a shout on here or @ http://www.mtbbatteries.co.uk he might be able to help!
Posted : 24/11/2011 12:55 am
Trent what did you decide in the end?
I dont like the look of the aluminium one, looks too big and the LCd screen is just something else that can break?
Posted : 23/12/2011 10:37 am
 cp
I have the larger enclosed battery on my MJ 836.
The battery is not THAT big - fits neatly under the top tube on the bike, or in the outer pocket in my Camelbak Mule.
Posted : 23/12/2011 11:02 am
And do you ever use the lcd function on the battery? Did it come with a bettery bag or just a velcro strap? looks like it would scratch your frame?
Posted : 23/12/2011 11:07 am
 cp
I use the LCD quite a bit - either to know if i have enough juice to go out for an hour, or to know where it's up to when charging, say just for a quick partial charge.
The top of the case is concave to shape to the frame & has a foam pad covering the entire surface. The strap is very broad and smooth - actually one of the better battery mounts I've seen. You can easily get it nice and tight so it doesn't move about.
Posted : 23/12/2011 11:12 am
I went for the black silicon sealed one in the end, after reading a review that the aluminium ones might not be totally waterproof due to the seals been incorrectly assembled in the factory.
Whats everyone elses battery life like? I seem to get the full 2 hours but the life indicator on the torch only shows green (100-75%) for 5 minutes, then blue(75-50%) for 30mins, then amber 30mins, then red 30, so a total of 1:35 hours, but it'll then keep going for another 25 mins with the flashing red 5% left warning.
Posted : 23/12/2011 11:32 am
where did you get it from in the end Trent (the light and battery)?
Seems to be numerous options and varying prices?
what did you pay also?
Posted : 23/12/2011 11:36 am
got it from this ebay seller, uk plug.
http://www.ebay.co.uk/itm/Magicshine-MJ-872-1600-Lumens-LED-Bike-light-/170741429377?pt=UK_SportsLeisure_Cycling_Bike_Lights&hash=item27c0fb7481#ht_1859wt_1398
arrived in less than a week
Posted : 23/12/2011 12:06 pm
I've got the big aluminium battery, it seems a quality bit of kit and the frame mounting really is superb. But I wish I'd got the smaller, lighter one tbh, since it lives in my camelbak anyway.
So I'd say alu one for frame mount, other one for bag use.
Posted : 23/12/2011 12:30 pm
