Hi,
I have a pair of Deore-ish level levers (M575) with knackered calipers.
I also have a pair of XT level calpipers (M765).
As far as I can see, the pistons in both calipers are the same diameter, but obviously its tricky to measure this accurately....
If I pair them together, will I die?
Thanks in advance....
BOAS
They will be fine.
I know someone who runs a Shimano lever with a Hope caliper filled with mineral oil, although I'd strongly suggest you don't do that.
I believe Jared Graves runs XTR race levers with Saint calipers, its a not an issue.
Cool. Thanks for that.
Will report back on success (Obviously if this is my last ever post then you'll know that it wasn't successful.....)
i broke a newish deore lever.
i replaced it with a much older* 'lx' lever.
works perfectly.
(*approx 1000 years old)
I have Marta calipers with Loise levers & use mineral oil.
