Mixing fork oil - h...
[Closed] Mixing fork oil - help
[#1776675]
Need 10wt but have 5 and 15wt - what ratio do i need to use?
Posted : 07/07/2010 10:09 am
I don't think it works quite like that...
I'm sure someone else will know better though
I'd just go buy the correct stuff personally 🙂
Posted : 07/07/2010 10:12 am
EDIT - Double post 😳
Posted : 07/07/2010 10:15 am
not for me 🙂
I'd mix the two 50 / 50
it is unlikely to be 10 w exactly but it will be near enough - assuming the two oils are compatable
Posted : 07/07/2010 10:18 am
I thought you could mix and dilute (not sure where from).
My thought would be equal measures of each to get to 10wt?
Let us know how you get on 🙂
Posted : 07/07/2010 10:19 am
Are they the same brand/type of 5 and 15wt? - some combinations don't mix well
When mixing oils -- not a good idea to begin with -- remember that one part 10 weight oil mixed with one part 20 weight oil does not make 15 weight. Rather, it's 13.3 weight
http://www.motorcycle.com/how-to/how-to-replace-fork-seals-3442.html
Posted : 07/07/2010 10:21 am
both rock oil
Posted : 07/07/2010 10:25 am
How crucial is it? Your forks have adjustment do they not?
if you want 10 w then buy some. If you are happy that its somewhere close to 10 w and that your adjusters will compensate than mix it
Posted : 07/07/2010 10:27 am
 Taff
I had 5 and 15 with my old boxxers and would mix equal amounts to get around 10. Always worked fine for me.
Posted : 07/07/2010 1:42 pm
