mix xx and xx1?
[Closed] mix xx and xx1?
[#6801738]
Converted my XX drivetrain to 1x10 a while back. Now i've just bust the cage on my mech. Given that replacing it is gonna cost me a fair bit anyway is it possible to replace the mech (and cassette) with XX1, or X01 for that matter and keep the XX crank? Anyone done this?
Posted : 22/01/2015 8:18 pm
Very limited choice of narrow wide rings in 80/120 bcd, if you're going that far I'd just change cranks personally.
Posted : 22/01/2015 8:38 pm
I've already got a N/W ring (WTC) from when I switched to 1x10, I'm just questioning whether a new 11 sp back end will work with it. Can't see why not but just asking if anyone else already did it.
Posted : 23/01/2015 12:02 am
will work fine, you'll need a shifter as well of course
Posted : 23/01/2015 12:24 am
You will need a new wheel/freehub to run an 11spd cassette.
Posted : 23/01/2015 12:40 am
Ah, good point about the hub, I hadn't considered that. Cost is rising, maybe I don't need that 42t cog after all.
I've now spotted a replacement carbon cage plate on eBay for £26 so will prob stick with 10 gears for now until I'm feeling a bit more flush.
Posted : 23/01/2015 12:47 am
You could use the XTR cassette, you'd 'only' have a 40tooth not 42 and 11 instead of 10 but you could keep your freehub body and the cassette is cheaper.
Posted : 23/01/2015 9:12 am
Sorry, missed the first 5 words about converting to 1x10 😳
Posted : 23/01/2015 9:23 am
