I currently have a full bar of controls on matchmaker clamps. I want to change some components round. (I am going 1x10 from 2x10, and also swapping to Shimano brakes)Â
Can someone shed some light as to if there is a suitable matchmaker type clamp which allows this or do I need to buy separate clamps?Â
I currently have:Â
Left hand matchmaker
X9 10sp shifter
reverb stealth remote
Elixr 3
Right hand matchmaker
X9 10sp shifter
Elixr 3
 I want:Â
Left hand
SHIMANO XT M785
(no shifter)Â
Right hand
SHIMANO XT M785X9
10 sp X9 shifter
 Â
[url= http://www.bikerumor.com/2013/02/25/frostbike-2013-problem-solvers-gets-sram-and-shimano-to-play-nicely-with-new-mismatch-adapters/ ]Problem solver[/url] for you right hand setup, can't help with the reverb lever as I've never seen one (possibly the problem solver again)
You can run a problem solver on the right but you won't need one on the left, if you run a RH Reverb upside down under the bars it marries in perfectly with the M785 brake (brake clamp closest to grip, Reverb inboard of it).
I had an M785 brake and XTR M980 shifter ran with an Ispec mount on the right recently but have gone back to a regular clamp as I couldn't get the positioning of the shifter just right for me
