Hi all,
Looking for a pump that I can mount to my frame/bottle cage mounts:
- Had a hose, rather than directly clamping onto the valve
- Durable - won't gum up when blasted with mud (as it will be mounted to the bike)
- Mount is as minimalist as possible - ie not really visible when the mount is not in use. Alternatively, a mount that is very easy to remove.
- Doesn't cost the earth
Does anything exist that meets the above?
Thanks,
Duane.
Topeak Mountain Morph.
Wot he said ^ Topeak Mountain Morph, mine a dozen years old, yes the foot broken off (I must order one) but it still works really really well.
Mount isn't very subtle :/
Lezyne
they come with a built-in valve core tightener now
+1 for the Lezyne offerings. Just be careful not to lose the rubber end caps (although thankfully they are available seperately)
Topeak race rocket is tiny, has a hose and a cover, and can be mounted under a bottle cage. Might be hard work pumping up an MTB tyre though.
Lezyne
Is this true or are you joking? My Lezyne mini pump is excellent in every way except it’s extremely annoying ability to remove valve cores so I wasn’t going to suggest it
Premier Icon
Rubber_BuccaneerSubscriber
Lezynethey come with a built-in valve core tightener now
it'a part of the hose now
8" alt="Lezyne hose" />
Syncros Boundary 2.0HV
Pretty good bits of kit their mini pumps but I do have to say the lezyne floor pump I have has been spectacular and nothing else has even been close to outlasting it!
Well my FWE pump fits all those except the hose bit. It's tiny and also fully sealed when closed up, which I've never seen before on any pump. So well sealed that I keep the roadie one on the frame in all weathers and nothing has ever got into it.
Flynt HV1.MTB Pump
Comes with bracket to mount alongside bottlecage. Rubber bungs in both ends for keeping slip out of the important bits and a silicone hose with dual ends for presta/schrader and aluminium body so it’s fairly tough
Ooh thanks for reminding me, I've been looking for a mini pump with a hose and push on head, had a disaster trying to pump up a stranger's tyres with my Lezyne pump, unscrewed valve core meant I left him with flatter tyres than he started with!
Thanks guys. Does the Syncros Boundary 2.0HV come with a mount? Not seen anything mentioned about one.
