Looking on CRC, they sell 32 tooth Uno for 8/9 speed chains but dont seem to have 34t other than for singlespeed setups. At this time of year I really want a 34t on the front of a 1x9 and would like to fit an Uno.
Anyone know if I can use a 34t singlespeed chainring with a 9 speed chain? They do 1/8" and 3/32" which I'm presuming are singlespeeds both.
I was going top do this and did a bit of research although it never went ahead...you can do 1x9 with Uno rings and you'll need the 3/32" chainring AFAIK
I run a singlespeed Blackspire Mono Veloce 32T up front on my 1x9 with a 9spd chain without any problems at all.
Thanks, will do a bit more research, be an expensive mistake if I order the wrong ring.
Just went through my emails as I remembered I'd emailed them...
"From: Matthew Starey [mailto:Matthew AT middleburn.co.uk]
Sent: 07 July 2008 11:13
Subject: RE: Middleburn general enquiry
yes you can
from Matthew
Sent: 06 July 2008 11:37
To: Matthew Starey
Subject: Middleburn general enquiry
Hi Matthew/Middleburn
Was looking at running a 3/32” Uno ring with a 9-speed cassette at the rear: can I use a standard 9 speed chain with the 3/32” Uno ring?
Cheers"
Nukeproof, top man. Thanks
