I have a set of RS7 square taper cranks, can I just buy an Uno chainring and it'll go together? Or are there specific Uni cranks that one needs to get as well? 😕
No, you're best off giving it to me Si. Those Middleburns are rubbish. I've got a nice Deore you can have, much better.
yep. I had a duo and just converted to a singlespeed with an uno
I think they look great
will fit your rs7s.
how does it go together? doesn't look clear from the pics I've seen... what are the spline things for?
They do look nice and neat, definitely 🙂
so do I need a specific tool for them then? 😕
Yes, the spider / uno chainring is splined and held onto the cranks by a lock-ring that requires the tool above left to undo it. No doubt a hammer and drift may do the job but you might then need to invest in a new crank 😳
what tool is that then?
Shimano XTR 950 BB tool
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=995 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=995[/url]
cheers guv... looks like this'll be more expensive than I thought... wonder if my friendly LBS will lend me the tool?
i didn't use a tool. A hammer and massive flat ended screw driver.
1st ride out today and all seems fine
Yo!
I've got the tool you can borrow...
Live in Ealing, Work in Holborn.
Drop me an email and we can work something out.
Or much cheaper than the XTR tool - but exactly the same:
[url= http://cgi.ebay.co.uk/IceToolz-BB-Tool-8-Prong-XTR-950-Middleburn-Lockring-/330508412004?pt=UK_Spots_Leisure_Cycling_Tools_RepairKits&hash=item4cf3d62464#ht_528wt_905 ]8 prong BB tool[/url]
I'd also recommend getting an Uno ring from this guy - [url= http://www.homebrewedcomponents.com/store.php ]Homebrewed Components[/url] - beautifully made, a bit cheaper than the Middleburn ones, and available in lots more colours and sizes.
Where do i get one of those (drools) ?
I think that will look good on my Jones 😉
In fairness, even the cheapest tat would look good on a Jones... 🙂
The Homebrew Components link above - I had to seriously force myself not to buy one of those when I was ordering an aluminium Uno ring.
very, very, very nice 😛 $140 - so about £100.......not too bad!
He also does Titanium SS sprockets in 2 flavours:
[img]
[/img]
[img]
[/img]
8)
You really ought to know better than show such a beauty here, it's a cycling forum so NOBODY rides 😉
Psychle, may I take this opportunity and congratulate you on the splendid 5:0 victory over the Poms? The Ashes were such an overwhelming success for the Aussies.
Would love a Boone, but good luck finding one! 🙁
I don't need luck , its mine 😉
spanner on the far right has a lock ring removal tool.
plenty of these sitting around in people's sheds.
worked perfectly for my middleburn.
[url= http://cgi.ebay.co.uk/4-OLD-VINTAGE-CYCLE-SPANNERS-TOOLS-MOTORCYCLE-BIKE-/230571782513?pt=UK_Bikes_GL&hash=item35af263171 ]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?VISuperSize&item=230571782513[/url]
Boone chainring or a Jones Spaceframe.... let me think..... 😉 I've been pondering getting 165/160mm middleburn - I think that Ti chainring has swung it, rekon a 30T would be nice 😀
Don't forget import duty....
Also do those flat looking rings give the correct chainline? My Middleburn UNO setup runs fairly close to the chainstay on [i]some[/i] frames. Close enough that the Ti ring looks like it could rub...
The Ti one isn't offset like the UNO and is about 2mm closer to the centreline.
True about the chainline - you'd need a slightly longer BB axle.
Import duty didn't effect the alu ring I bought, but would probably come into play with the Ti one.
OOOhhhhhhhh.Ti 32 ring for my xtr960's and a 2part ti 18t sprocket thankyouverymuchly
