Middleburn Thick Th...
[Closed] Middleburn Thick Thin Woes
[#7270066]
Is anyone else using a Middleburn TT (Thick Thin) and having problems with dropped chains?..
I fitted mine on a RS8 crank and run it 10 speed with a Zee clutch mech, after dropping the chain 2-3 times per ride I fitted a Pauls chain keeper which has brought the chain dropping down to 1 or 2 occasions and over particularly bumpy terrain or when gassing it over tree roots, but the chain then jams in the chain keeper...
Its a bit frustrating and short of fitting a Stinger device I'm running out of options... Is this happening to anyone else?
Posted : 16/08/2015 9:28 pm
Chain the right length? Clutch working properly?
Posted : 16/08/2015 9:31 pm
Not middle burn but did have issues with race face.... But don't actually think it was anything to do with the narrow wide narrow ring.
In my case I just needed to tighten the band on the clutch mech providing a bit more tension.
Guide here :
http://bikefat.com/tech-how-to-adjust-the-shimano-shadow-plus-rear-derailleur-clutch/
Posted : 16/08/2015 9:32 pm
This is the first foray into Clutch mechs for me and the chain length is good. I will give that adjustment on the clutch a try... thanks don 🙂
Posted : 16/08/2015 9:47 pm
running xx1 1x11 on a fattie with RS8 not 1 drop in the year i have ridden it, even on a week long trip to rocky spain never had any issues. chain line is a little iffy on 42 chain ring though..
it is a 32 hope narrow wide up front chain ring.
Posted : 16/08/2015 10:56 pm
I've been running a Middleburn fat/thin hardcoat chainring for the last 6 months or so, standard 104 bcd on saint cranks without a single dropped chain, everything has just worked. Ok, I'm not sending road gaps but it's not been thrown by anything I have chucked it at.
Posted : 17/08/2015 8:12 am
 br
Sounds like you might not have your BB spacing right?
Posted : 17/08/2015 8:49 am
Middleburn 32T thick/thin just fitted and it seems fine.
1x11 XT and was fairly generous when i set the chain length, dropped the suspension fully and then the 2 link overlap (or 4 if you count individual the links and not pairs)
Posted : 17/08/2015 9:03 am
I run middleburns 1x10 with zee rear mech and have no issues with chain dropping at all in UK trail riding (and even with a week in les 2alpes with a mrp 1x guide fitted). I'm running a wolftooth ring and not middleburns own effort though.
Posted : 17/08/2015 1:21 pm
I seem to drop a chain 3-4 times /ride... Running a middleburn TT 10spd with Sram x9 clutch mech, and little chain keeper.
Have found it very frustrating – It seems like the thick part of the ring can still fit into the thin section of the chain, so wondering if it's only really suitable for 11 speed?
Posted : 26/08/2015 9:14 pm
@liamh Must admit I'm not convinced the slightly elliptical shape of the Middleburn TT helps with using the chain keeper as I couldn't get it in the right place to consistently work as a guide, then to have the chain jam in the keeper was so annoying... I wonder if these are suitable or if there is an issue?
#edit... I got so pissed off with the whole gears thing I've returned to Singlespeed again.
Posted : 27/08/2015 8:10 pm
