Middleburn duo ques...
[Closed] Middleburn duo question
[#3059934]
Can the duo rings be used as part of a 2x10 setup or am I restricted to a 2x9?
Posted : 18/08/2011 9:01 am
It'll be ok, may not shift quite as well, but then you bought Middleburn rings, so shifting quality obviously isn't a priority 😉
Posted : 18/08/2011 9:02 am
excellent, ta!
Posted : 18/08/2011 9:24 am
+1
The Duo is a good example of a good idea , poorly executed.
Posted : 18/08/2011 9:25 am
please explain - why is it poorly executed say in comparison to the latest sram incarnations?
Posted : 18/08/2011 9:40 am
Hi
My mate tried running X-type cranks duo with 10 speed and really suffered with chainsuck. He discussed it with Matt at Middleburn. The rings are designed 9 speed (10 on the way).
I now have his set-up on my bike but running 9 speed and no problem. A way round it until Middleburn do 10 speed rings may be to use the triple spider using someone else's rings
Posted : 18/08/2011 9:51 am
I got the latest middleburn 4 arm duo's and have run them with 9 and 10 speed set up, no difference in shifting, not the greatest but its middleburn and British so will always get my support.
Posted : 18/08/2011 4:28 pm
I prefer running my Renthal (32T) and Truvativ (42T) rings on a Middleburn dual spider than the Middleburn Duo rings on my other set up.
Gives a better set of options, ring wise, for a very comparable weight.
Posted : 18/08/2011 4:32 pm
