Middle chainring / ...
[Closed] Middle chainring / Orange 5 compatibility
[#2377789]
Thinking of loosing the outer chainring to try a 2x9 setup. Can you run a 36T or 34T middle ring on a standard triple chainset on the five? The 32T I have currently seems awfully close to the swing arm pivot already and there are obvious signs of chain damage - could be from the previous owner running a different size middle ring?
No email address on the Orange website and I'd prefer not to call from Oz unless I have to.
Thanks
Posted : 17/01/2011 8:54 pm
36t needs the chainline moving out, I've got the gouges to prove it. Swap the spacers around on the Bottom bracket.
Posted : 17/01/2011 9:05 pm
 lcj
36t in the middle ring worked fine for me on standard spacing with a 2010 frame. It caught on the swingarm occasionally when in a workstand but once you factor in sag theres no problem in my experience.
Posted : 17/01/2011 10:02 pm
I run a 2010 five frame, size medium with a 36th middle ring and xt cranks with a gamut fitted and the clearance is fine, close but never had any problems.
Hugh
Posted : 17/01/2011 11:04 pm
This is on a 2006 frame. I guess they have modified it to give clearance.
Posted : 17/01/2011 11:06 pm
Yes, mine is 2005 so very similar, if not identical in this area. A single ring could be fine, my concern is changing to/from the granny. Only have one BB spacer on the drive side (73mm BB) so not following you there? Maybe I could get away with adding a second one on the drive side?
Posted : 18/01/2011 10:35 am
