Meta 5.5 owners
[Closed] Meta 5.5 owners
[#602845]
Does anyone else blow through the travel to easy? clipping pedals off 3" high roots is getting a bit boring 🙁
Posted : 03/06/2009 10:43 pm
Never found it to be a problem. Can't remember what pressure I've got the shock at but I run quite a lot of sag and never seem to push the O-ring off the shaft.
Posted : 03/06/2009 10:51 pm
I'm running about 260psi now, sure the float can only take 300.
I'm pretty sure mine's about 150psi. I'm about 13 stone with all the usual trail kit. Sounds like something funny's going on 😕
Posted : 03/06/2009 11:03 pm
I'm 17 stone. that's the bother 🙂
Posted : 03/06/2009 11:07 pm
 BigR
13.5 stone and 150 psi - never blown through the travel. I think your shock is knackered. I'd give Mojo or TF a call.
Posted : 03/06/2009 11:10 pm
I'm 14.5st kitted up and run 170psi which works best for me. I did run as low as 150psi for a while but got fed up of clipping pedals when climbing. The bike does sit quite far into it's travel and pedal clips are common but I've only ever once bottom it out after a flat landing from a jump.
260psi is crazy, sounds like somethings up with your shock.
It's not actually bottoming, I just get through the travel very easily. It's been like that since new, and I'm convinced it's my weight rather than anything else. It's fine going downhill, and I'm usually going too slow uphill for it to be a bother, it's pedally bits with roots or dips in quick succession where I can't keep up the momentum that gets it.
Reading that, I'm wondering if the rebounds a bit slow and thats where I'm getting caught out 😕
Posted : 03/06/2009 11:16 pm
When I had mine would tend to use alot of the travel, but I think that was what made it ride so well. The trade off of this nice and low riding position is pedal strikes unfortunatley. I compounded it by having wide flatties, but meh you get over it. If you have a bike that rides high enough to avoid pedal strikes it feels too tall (Like the Marin Quad Links in my experience).
Posted : 03/06/2009 11:48 pm
rebound or pro pedal settings? does it have a lockout for climbing? You can also get the floats with different pro pedel settings.
Maybe time for a return to seller for some setup tips etc
Posted : 04/06/2009 12:14 am
It's just a bog standard float r with a factory set medium propedal, no lockout.
There's no noticeable bob either.
Posted : 04/06/2009 12:24 am
