Met Parachute sizin...
[Closed] Met Parachute sizing advice please
[#6809770]
Hi All,
What are your opinions regarding sizing for the new Met Parachute?
Do they come up large typically as have been tempted by a second hand one in Medium but I have a 59cm bonce?
I've got away with 58cm Giros in the past so realise sizing isn't necessarily the same for all manufacturers...
Cheers! :0)
Posted : 25/01/2015 9:43 pm
I'm 59cm too, medium was just doable large was huuuuge, was too big even on minimum adjustment.
Had to send it back though as it just didn't suit my head.
Posted : 25/01/2015 10:52 pm
Nice one thanks Blue!
Posted : 25/01/2015 10:59 pm
My noodle is also about 59cm I ordered both M and L... M was just a bit too tight and the chain bar felt high and chin was out below it... And the large would have fitted my big arse head plus a cowboy hat and still have room... Sent both back and got a large bell super 2r that fits perfect.
Posted : 25/01/2015 11:00 pm
Sounds like 'try before you buy' then!
Thanks Chris!
Posted : 25/01/2015 11:12 pm
Always had Met helmets in a large but last years models the large was huge and the medium just fitted with the adjuster all the way out, I went for a medium only problem is I cannot wear a cap during winter!
Posted : 25/01/2015 11:14 pm
I have always had large MET helmets in the past but I'm definitely need a medium for a Parachute the large was way too big.
Posted : 25/01/2015 11:42 pm
Thanks all! :0)
Might take a punt on a medium...
Posted : 26/01/2015 11:39 am
Didn't read this before buying, but bought a large recently for 60-61cm head and way too big/Wobbly. Ordered a medium in its place, but from reading this thread it looks like it'll be too small! Lucky the website has free return postage. Bell super 2r it may be...
Posted : 14/02/2015 6:13 pm
Same here .. Im a medium with a 58cm heed and my met is a perfect fit
Posted : 14/02/2015 6:20 pm
Ordered a large for my 58cm head this week (also before seeing this thread) but was too big so have returned it for a medium.
Was intending on getting a Bell Super 2r but the medium I tried in the LBS was too small and the large Super was too big.
The Parachute is nicer IMHO.
Posted : 14/02/2015 7:08 pm
i bought a large, the head fitted ok but the chin guard was much too big and wasnt tight, i decided not to get the medium as i hadnt realised they came with a d buckle which is a faff if you take your helmet on and off a lot, i now have a super2R fits better, but im not sure it is better
Posted : 14/02/2015 7:44 pm
Just an update on this - the Medium parachute arrived and does not fit at all! It's just about ok with dial all the way out (for my 60cm head) but the chin bar is so high it's ridiculous. Chin sticking out the bottom loads.
Also ordered the Bell Super 2R in Large and it's fantastic! Decent fit, comfortable, looks lovely and the detachable chinguard will come in really handy. Plus it doesn't have an annoying D-lock mechanism.
V pleased with it. Hopefully it'll be cool enough for the general trail riding I intend to use it for.
Posted : 19/02/2015 1:04 pm
I have a MET Parachute,go for Medium. I'm 59cm noodle and it is a great fit in medium sizing. 🙂
Posted : 19/02/2015 1:13 pm
Quick question about fitting: -
The Large Bell Super 2R fits well when the dial is almost completely tightened. It stays in place when I wobble it, is snug, without being tight and uncomfortable.
But is it a bad thing that when the dial is not tightened, the helmet is quite loose on my head (not helped by the very round, wide shape of the upper piece). But I just can't see the medium fitting my 61cm head.
i.e. is it ok to rely on the retention system to ensure good fit, or should it fit fairly well without?
Posted : 20/02/2015 2:15 pm
