Merino baselayer fo...
[Closed] Merino baselayer for warm weather?
[#3793375]
Ive had a long sleeve merino base layer over the winter and found it great. Now the summer is coming I want to get a short sleeved base layer to replace my old under armour one. Are merino ones good for summer use aswell or am I better sticking too getting another under armour type one?
Posted : 20/03/2012 9:57 pm
I have ridden in pretty warm weather in a Rapha Fixed long sleeve jersey and been comfortable. BUT - that was the only top being worn. I do think merino is pretty good and it is a very rare manmade fibre one that approaches the same feel. I do actually have a Berghaus base layer that is close though it cost as much as the majority of merino base layers.
I would say though if you want something for wearing under armour I'd suggest a "string vest" type in man made fibre. A lot of roadies swear by Prendas base layers.
See - http://www.prendas.co.uk/details.asp?typ=typ&fkid=22&ID=368
Posted : 20/03/2012 10:31 pm
I have several short sleeved merino tops - brilliant for cool conditions worn under a short sleeved top. OK when it gets hot, but if I had to choose, in such conditions I'd go for a synthetic - CoolMax works well, but there are other alternatives.
Posted : 20/03/2012 10:37 pm
I love my icebreaker ss top, but it shows the sweat so badly when I'm warm that I've pretty much stopped wearing it altogether.
Posted : 20/03/2012 10:52 pm
I ride merino base layers all year round. Only short sleeved in the hottest weather.
Posted : 20/03/2012 10:54 pm
wear my sugio all year as base layer on and off bike
Believe it or not Rapha merino is a bargain if you buy in a bundle of 3. I wear them (long and short sleeve) all year apart from high summer. Need to hand wash them though as a bit fragile but combined with a couple of Icebreaker 200 you will be set for woolies.
£110 for 3. Worth it.
http://www.rapha.cc/base-layer-3-pack/
Posted : 21/03/2012 11:09 am
merino all year round for me too, find it regulates my body heat very nicely.
Posted : 21/03/2012 11:24 am
Quite a big fan of Merino base layers but in summer I find them too obtrusive. They wick and disperse perspiration very well but if they do get saturated that's it, game over.
As above it's synthetics for me when it gets hot. The compression fit base layers are incredible I can feel myself cooling down after just a few minutes inactivity.
Posted : 21/03/2012 11:42 am
Another fan of merino in winter here. BaBa long sleeves worn on every ride since November.
A mate of mine swears by his Rapha short sleeve jersey but I wear a Skins C400 compression layer or just a short sleeve synthetic jersey in warmer weather.
The C400 is incredibly cool and must have powerful wicking properties.
Posted : 21/03/2012 12:57 pm
Do you guys wear a synthetic base when its really hot? Sometimes see guys on the Tour doing so......can it actually cool you?
Try bamboo base layers little known but superb
Posted : 21/03/2012 1:07 pm
Merino base pretty much all year for me. If it's really warm (25 degrees plus) then I'll go for a synthetic vest with a mesh back just to keep the wind off, but I'll always have some kind of base to wick perspiration away otherwise I find I'm pouring in sweat in minutes.
Posted : 21/03/2012 1:10 pm
Why on earth would you want to keep the wind off if it's that warm 😕
I don't wear base layers at all above about 15 degrees, keep meaning to try a summer weight one, but just prefer a road jersey on its own if it's hot.
Posted : 21/03/2012 1:12 pm
Absolutely. Compression base layers are by their nature skin-tight and they soak up perspiration like a kitchen towel and disperse it over the surface where it evaporates very quickly taking the heat with it. Like skin, only better.
Posted : 21/03/2012 1:16 pm
Very thin merino tends to get quite delicate. If you want something lighter but still merino-esque, check out Rab's lightweight merino/cocona mix - dries and wicks faster than pure merino, is more durable. Good stuff.
Posted : 21/03/2012 1:22 pm
Merino's great at this time of year - it regulates your temperature well enough to be comfortable for a fairly wide temperature range. I only stop wearing a base layer when it gets properly warm. I haven't tried any of these new-fangles compression tops though.
Posted : 21/03/2012 1:23 pm
Yes they are very good, Plenty off mesh rad c nesbit ones that work very well. Most aren't compression.
The mesh will regulate air flow around the skin and wick moisture away.
A good synthetic will dry far quicker than merino.
Posted : 21/03/2012 3:02 pm
as above the mesh vests are very good in a different sort of way. Cooling via improved airflow and a large surface area to disperse perspiration without convering the skin like a solid fabric.
Posted : 21/03/2012 3:31 pm
Robbo, I'm not sure where your riding takes place 'geographically' but for up here in sunny Scotland I cant look past my BaaBaa's long sleeve / short sleeve tops. They're used every day for my commute down to temps of circa -5. Below that I pop on my medium Icebreaker. Throughout the summer I simply aternate between my long sleeve top and short sleeve top. Cool in the summer, warm in the winter. They dry super quickly and dont stink after a couple of rides....according to the wife 😉
Posted : 21/03/2012 3:52 pm
Merino sheep wear theirs in summer and winter alike!
Posted : 21/03/2012 4:13 pm
Yeah but have you seen any happy sheep??
Posted : 21/03/2012 4:15 pm
Particularly on a road bike, the temperature differentials can be just as high in warm temperatures - yes you want to be cool slogging up a hill, but if you're sopping wet in sweat and then head straight into a long, fast descent you're going to get chilled very easily. OK, more of an issue in the Alps or Pyrenees than the UK I'll admit but valid nonetheless.
Posted : 21/03/2012 5:41 pm
Sugoi merino is very thin but goes in machine on 30 degree wash. Think most technical thin merino is a mixture of technical material and merino. Used day in day out washed about once every 10 days
Posted : 21/03/2012 7:25 pm
Wear Merino all year round - summer just wear base layer like a Baa Baa SS top on it's own - fantastic. Just bought some Howies SS merino ride tops half price in sale so set for summer. Only ever wear synthetic tops now in winter for waterproofing. My polyester SS tops now confined to the bin.
Posted : 21/03/2012 10:29 pm
