Mending gashed tyre...
[Closed] Mending gashed tyres
[#5576230]
Stuck a half cm gash is my reasonably new racing ralph tyre the other day. Was running tubeless and wouldn't seal up.
Put in a tube and it runs fine, however am I able to repair the tyre to run tubeless in future? Gash is on top of tyre rather than sidewall if that makes any difference.
ta
Posted : 05/10/2013 8:16 pm
Ive repaired sidewalls with no problems tubeless. Stitch with dental floss and put a large patch on the inside to seal and outside to protect stitching. May be a bit tricky to do on the tread though?...
Posted : 05/10/2013 8:31 pm
 nuke
Half cm gash doesn't sound too bad. I found this article on pinkbike useful...
http://m.pinkbike.com/news/Tech-Tuesday-Three-Ways-to-Save-A-Leaky-Tubeless-Tire-2012.html
Might get away with the plug method on half a cm.
Just repaired a 1.5cm+ gash in the sidewall of a Minion with just patches and that's back up and running tubeless
Posted : 05/10/2013 9:39 pm
5mm? Stick a sticky worm in there
Posted : 05/10/2013 9:41 pm
