Mech Disk Brake cab...
[Closed] Mech Disk Brake cables - same as gear cables?
[#1902217]
I'm building up a hibred bike: actually, I've bought a new (bigger) frame so I am moving all the parts over from one to the other.
The brakes are mechanical (cable) disk brakes. I need new cables for the new bike. What type of cables should I be using? Are they just the same as normal gear cables, like these:-
[url= http://www.wiggle.co.uk/p/cycle/7/Transfil_Gear_Cable_Inner/5360008455/ ]Gear cables[/url]
(for example)
Thanks
Posted : 17/08/2010 9:30 am
No, brake cables, though some (inc. me) have run gear inners for less friction.
Posted : 17/08/2010 9:31 am
No, like Al said. I got one of the brake cables from the same brand as you linked to from Wiggle and it works fine for the rear brake. Still not as nice as the Nokon cables I have up front though, but a full-length housing worth as much as a pair of hydraulics just didn't seem too clever.
Posted : 17/08/2010 11:13 am
Use standard brake cables and try to keep the outers as short as possible. If you use full length outers you will end up with a spongy feel as the outer compresses.
Posted : 17/08/2010 11:33 am
Thanks guys
Posted : 17/08/2010 11:36 am
