Maxxis tyres- when ...
[Closed] Maxxis tyres- when did Marzocchi start producing them?
 hora
[#1252457]
Seriously, jsut removing a mint Swampthing to put on a Ardent (bought at the end of Summer/4rides?) and both sides are almost threadbear in parts- looks like Ive ridden a fair distance on them with a flat. Why?!
Same happened to a Larsen (however that was one ride).
Older Maxxis's I own are fine and those are single ply as well.
Anyone else?!
Posted : 23/01/2010 6:59 pm
yeah, my sidewalls are showing through too. Pretty much all around the tyre on both sides. Tread wear is fine. Mine's a minion rear (single ply), about 5 months old and not had that much abuse.
Posted : 23/01/2010 7:05 pm
Running at too low pressures?
Posted : 23/01/2010 7:21 pm
I'm running non-UST tubeless, so they can't be that threadbare.
What's Marzocchi got to do with it?
Posted : 23/01/2010 7:23 pm
 hora
TJ- 35psi and I havent pinchflatted. Do you think it could be that though?
Posted : 23/01/2010 7:24 pm
Something is causing the sidewall to fret and wear - just a guess from me but the lower the pressure the more the sidewall flexes
Posted : 23/01/2010 7:26 pm
I typically run 50psi in my 2.35 HRs.
Grip is soooo overrated...
Posted : 23/01/2010 7:27 pm
 hora
50psi? Grip AND fillings!
Hang on. It cant be the psi that Im running. Ive used my Swampthings constantly (front and rear) and they dont have a single mark on the sides.
The Ardent/Larsens actually look like Ive ridden on the rims for miles.
Posted : 23/01/2010 7:44 pm
me no get the marz link ?
Posted : 23/01/2010 7:45 pm
 hora
I had 4 Mazz forks that had quality control issues.
Posted : 23/01/2010 7:46 pm
Is it not just the innermost layer having exposed 'threads'? There's no need for the inside of the tyre to look tidy and smooth.
Posted : 23/01/2010 8:15 pm
 hora
boxelder- its the external sidewalls showing the threads.
Posted : 23/01/2010 8:16 pm
 D0NK
I get the same on prettyt much all offroad tyres but pretty sure thats from running low pressure (35psi also and yes I consider that low).
Oh and I rather like my Z1s.
Posted : 23/01/2010 8:32 pm
I had this happen. Contacted the importers, sent them pics, and they sent me a new tyre.
Posted : 24/01/2010 8:45 am
 hora
Brainflex, will do.
Posted : 24/01/2010 9:26 am
mine show too... but in fairness haven't got any worse; looks 'wrong' but still works fine.
I run 35psi - ish too...
Posted : 24/01/2010 12:06 pm
my advantages have been like that for nearly a year, no adverse effects.
happened with my NNs too, and some bonty ACXs etc etc etc...
Posted : 24/01/2010 12:30 pm
Could it be that the tyres have been sat around for a while since production and before purchase and the rubber has degraded in that time?
Just a thought, no idea if it has any bearing what's happening to them?
Posted : 24/01/2010 1:14 pm
