Maxxis Tyres / Stan...
[Closed] Maxxis Tyres / Stans Flow / Tubeless
[#2936701]
Converted to a tubeless setup a few months back after a bad run of punctures (9 in 3 weeks). After some initial setup problems, specifically with the Larsen TT I run on the rear, it's been great.
What I have noticed though is tyre squirm. When riding technical, loose, rocky trails and, for example, leaning the bike in on berms, there is an element of tyre squirm where the sidewalls must fold.
Its not a sensation that I like and wondered what could be done to resolve it. I'm running 35-40psi in both tyres (so not low pressures) but wondered if buying UST specific tyres would stop this from happening? Presumably, these have thicker sidewalls?
I'm off to the Alps in September with MBMB and wondered if it was worth upgrading to UST specific or Dual Ply.
Posted : 12/07/2011 11:51 am
 D0NK
I run minion dual ply on flow rims, not noticed squirm but I run 45ish psi. Heavy but I aint pinched it yet. For alpine I'd def go dual, you can get UST dual ply to cover all bases.
Oh and yes UST tyres have thicker sidewalls, I still manage to pinch them occasionally tho.
Posted : 12/07/2011 11:54 am
Cheers D0NK, I'll see what UST/Dual Ply tyres I can get my hands on.
Would quite like to keep the same 2.35 HR front / 2.35 Larsen TT rear as this offers grip and fast rolling. The MBMB 3 Countries Tour requires plenty of (uphill) pedalling as well as downhill.
Posted : 12/07/2011 12:01 pm
 MSP
Are you getting squirm on both tyres or just the rear?
I have given up on very light tyres for the rear, but don"t have any problem up front, I suggest going for a slightly heavier tyre at the rear, but still probably not necessary to go for a full ust tyre.
I currently have continental protection on the rear and race-sport on the front, and I am pretty heavy.
Posted : 12/07/2011 12:29 pm
Tyre squirm is related to tyre pressure and sidewall strength. Your pressures aren't very low, so I'd get something with stiffer sidewalls (UST or dual ply) there will be a weight penalty, which if you don't like, just up your pressures.
Posted : 12/07/2011 1:32 pm
Non-UST Dual ply Maxxis seal pretty well on UST rims with a bit of soapy stans jizz.
Posted : 12/07/2011 1:49 pm
Had the same issue with single ply minions, managed to burp the rear tyre off of the rim twice.
Changed to dual plys and no issues since.
Posted : 12/07/2011 2:04 pm
 D0NK
Ah I read alps and thought "uplift" dual ply are seriously chunky. Try UST first or up your pressures.
Posted : 12/07/2011 3:14 pm
