Maxxis tyre compoun...
[Closed] Maxxis tyre compounds (dual compound)
[#9451290]
Does anyone know whether the dual compounds differ between a Minion dhr 2 (believed to be 62a-60a) and the dhf? i have seen that maxxis also do a dual compound which is 52a-60a
Posted : 22/07/2017 9:57 am
I'd love to know the actual ratings for all their different tyres.
I've avoided a dual compound DHF up front as I assumed it would compromise grip and similarly, looking for a dual compound for the rear to avoid excessive wear. However, if the dual varies with tread design, I might be barking up the wrong tree.
Posted : 22/07/2017 10:07 am
There is a lot of good info here but it doesn't really answer my question
http://nextday.bike/Information.aspx
Posted : 22/07/2017 10:21 am
Yeah, I've seen that before. It only skims the surface though.
Posted : 22/07/2017 10:32 am
It's all a bit confusing. But I do know that a dual compound DHR2 rolls way faster than the 3C version, in fact it's not much slower than a dual compound Minion SS. It also wears much more evenly on the back, keeping a better edge on the side knobs.
For the front I'd only run a 3C, unless you're solely a dry conditions rider (do they exist in the UK?)
Posted : 22/07/2017 12:30 pm
i agree, im really impressed with the dhr2 dual compound.
Posted : 22/07/2017 2:40 pm
I've also tried to get numbers off MAxxis but they seem reluctan o give them out for some reason.
As far as I can make out the dual compound aggressive tyres (DHRII, High Roller etc) have a softer compound mix than the XC tyres (Ardent, Crossmark). I happily run a dual DHRII on the rear with a 3C upfront on the big bike and dual compound Ardent/CrossmarkII combo on the small bike so it's not a case of 3C front/dual rear!
Posted : 22/07/2017 2:48 pm
i have been running a dual compound on the rear and 3c front like a lot of people. I'm considering going from a 3c minion 2.3 on the front to a minion dual compound but in a 2.5
Posted : 22/07/2017 3:30 pm
This [url= http://www.bitingtires.com/tire-database/ ]linky[/url] may help, but I don't know if it is accurate.
Posted : 22/07/2017 8:15 pm
 leth
I always run a maxxgrip on th front but have swayed towards a duel conpoud on the rear. After 2 weeks in morzine the front has lost all its edges. The rear tyre still looks pretty new.
Posted : 22/07/2017 10:48 pm
rotary - Member
I honestly wouldn't, the dual is fine til it's not, which will most likely be on some greasy pile of rocks. If 2.5 makes sense for your riding then dual compound front doesn't imo.
Posted : 23/07/2017 2:22 am
