Maxxis new 2.25 Vs ...
[Closed] Maxxis new 2.25 Vs old 2.35 size wise?
[#3981379]
Am I correct in thinking a maxxis 2.25 tire like an ardent or crossmark sizes the same as a high roller 1 or minion dhf 2.35?
Which is larger or smaller? I like the old 2.35 size for most stuff.
Cheers for your experience :mrgreen:
Posted : 16/05/2012 7:04 pm
I reckon a new 2.25 comes up somehwere between an old 2.35 and 2.5 - probably more towards the 2.35.
This is comparing a Crossmark 2.25 LUST to 2.35 / 2.5 Mk1 High Rollers.
Posted : 16/05/2012 9:43 pm
a little bigger. As above comparing a 2.25 crossmark to a 2.35 highroller
Posted : 16/05/2012 9:50 pm
Perfect, thanks for the advice.
Any ideas of the faster rolling - Advantage V Ardent 2.25? :mrgreen:
Posted : 16/05/2012 9:59 pm
My 2.25 Ardent is slightly bigger than my 2.35 Minion DHF. It is also considerably faster rolling than my 2.1 Advantage.
Posted : 16/05/2012 11:09 pm
The ardent does roll faster thn the advantage but is scary in the wet. A rear summer choice only unless you only ride trail centres IMO.
Posted : 16/05/2012 11:12 pm
Was going to keep my minion 2.35 up front so it is a choice for the back as my lust HR is dying and was dragtastic.
Posted : 16/05/2012 11:30 pm
I reckon my 2.25" advantage is about the same overall volume (tread+carcass) as my 2.5" high roller. I reckon a 2.25" advantage might have slightly more carcass volume. tread is lower
certainly a fair bit bigger than my 2.35" high roller, 2.1" crossmark or a 2.35" larsen TT
A bit bigger than a 2.25" Schwalbe NobbyNic/Albert, which is about in the middle between 2.35" HR and 2.5" HR/2.25" advantage
Probably about the same as a 2.2" Bontrager XR4 (at least the 2009ish-2011 one
Probably only slightly bigger than a 2.2" Specialized Purgatory
Ceratinly a fair bit smaller than a 2.3" Spesh Eskar
Posted : 16/05/2012 11:38 pm
