Maxxis Advantage 2....
[Closed] Maxxis Advantage 2.1 vs Fire XC Pro 2.1 - how much bigger?
[#6221415]
Looking to get some higher volume dryer weather tyres for my 120mm full sus XC / trail bike and need some recommendations regarding size / volume.
I've been riding Fire XC Pros for the past 6 months and while they are a great tyre with tons of grip in the mud / wet, they size up really small.
After a bit of research I've decided to grab a pair of Advantages but I've seen that they come in 2.25 or 2.1 size. I've heard that the 2.25's are more like a 2.4 so these might be a bit overkill, so how do the 2.1's size up?
Posted : 26/05/2014 8:59 pm
Not much between them in 2.1's TBH, the maxxis is slightly bigger. If you want to size up then go for the 2.25's.
Posted : 26/05/2014 9:17 pm
I have a 2.1 advantage on front of my HT and I love it. One of the tyres I use on the rear is a 2.1 Ground Control Spesh and size wise they are very similar.
Posted : 26/05/2014 10:31 pm
2.25 advantage is a lot bigger than 2.1 fire xc, 2.1 is a bit bigger. I've used all 3 at different times.
Posted : 26/05/2014 10:48 pm
As far as 2.1" tyres go, fire XCs are sensibly* about as small as you'll find a 2.1" and an advantage 2.1" about as big as you'll sensibly* find. imo there's a fair bit between them
as far as I remember a fire XC is nearly as small as a high roller (XC) 2.1" and the advantage nearly as big (mostly the tread is lower) than a 2.35" high roller mk1 for eg
Posted : 26/05/2014 11:12 pm
