MaxxGrip vs MaxxTer...
[Closed] MaxxGrip vs MaxxTerra
[#10194037]
minion DHF flavour, is there any point not going for MaxxTerra when the 2.5WT MaxxGrip is only a few ounces heavier.
is it going to wear considerably quicker or be substantially more draggy when used up front?
Posted : 28/08/2018 4:51 pm
Grippy = Wears faster more draggy
Terra I think are the faster rolling ones
Posted : 28/08/2018 5:00 pm
Cheers, will the maxxgrip be too draggy for Cannock?
Posted : 28/08/2018 5:14 pm
On the front it's not too draggy I've got the dhf 2.5 max grip and it's a great tyre
The wear rate has been good too about 3-4 months in and the edges are just rounding off now
Posted : 28/08/2018 5:21 pm
I have just put a 2.5 DHF maxxterra on the front and it's a great tyre. Can't compare to the maxxgrip but the grip of the terra is bob-on.
Posted : 28/08/2018 6:32 pm
Fitted a 2.5 DHF maxxgrip a couple of weeks ago and it's grippier than a grippy thing. I kind of think that if you're fitting a 2.5 DHF then grip is probably high up your priorities, so might as well go for the compound with more?
Posted : 28/08/2018 7:08 pm
Got a 2.5wt maxxterra dhf on the front, tread is lasting well
Thinking of putting the same on the rear
Posted : 29/08/2018 12:15 am
Are you mad? DHF on the rear? not my cup of tea!
Posted : 29/08/2018 8:52 am
Assuming your not joking - you do realise a DHF works really well on the rear?
Posted : 29/08/2018 9:44 am
Why not? plenty of grip!
As Legend says they work well, plenty of people use a dhf on the rear
Wish Maxxis would make a exo casing maxxgrip 29er. At the end of the day you notice the dh casing up front after 25miles/5000ft !
Posted : 29/08/2018 10:20 am
Not sure about maxxgrip/terra but was there not a thread a bit back saying the triple compound version was not great in colder weather, and better sticking with dual compound in the winter?
Posted : 29/08/2018 10:32 am
