Hello,
I have some new wheels with a 20mm Hope pro2 hub on. Just looking for some forks as the ones i was getting have been delayed. Found an ideal set but they are listed as having 'Maxle Lite FR' would this fit in my hope 2 pro hubs?
THanks
Ed
If they're 20mm rather than 15mm, then yes. You need to double check the axle size as Maxle is available in 2 sizes from Rock Shox.
Mind you, the adapters to swap from 20 to 15mm are only £15 anyway...
Does it say if it is 20mm?
It could be 15mm. Ether way it will fit in a Pro 2 hub with the correct adapters.
A link to the forks would help.
GOod point, wasn't aware you could convert.
I've found out elsewhere it's 20mm so all is peachy 🙂
Thanks guys
