Maxle Damage-is thi...
[Closed] Maxle Damage-is this normal?
[#4456777]
Sorry for those who already answered on the badly titled previous topic.
Just had my first puncture on new bike and went to undo the rockshox maxle to remove front wheel and found that the cut out that gives the grip to turn the thing has chewed up. I managed to get it off but am a bit peeved that its happened as the thing is only a few months old. Is this a common thing to happen to this part? Have I caused it by over tightening? Can I claim on warranty?
J
Posted : 14/10/2012 3:01 pm
Here are the other bits of the other topic so you don't have to repeat yourselves
J
POSTED 35 MINUTES AGO #
patriotpro - Member
"Chewed up"?
Pics?
POSTED 27 MINUTES AGO # REPORT-POST
Northwind - Member
It's normal for them to wear a little in use but if this is the first time you've had the wheel out, that'd suggest crash/scrape damage rather than wear?
POSTED 22 MINUTES AGO # REPORT-POST
johnj2000 - Member
Just noticed the title of this topic! Maxed question? Bloody auto correct.
Sorry I didn't make myself clear up there^^ I have had it n and off for cleaning and transporting but hadn't noticed anything major but today a chunk of the metal just sheared off when I was trying to undo it. I would take a pic but its pointless as I can't for the life of me figure out how to put a pic up n here without linking to flikr.
POSTED 3 MINUTES AGO # EDIT
Posted : 14/10/2012 3:03 pm
Mine is the same. Within 2 months of having the bike, the cut out has rounded off. It still works, but the material that it is made of must be so soft.
I reckon it took about 10 times of removing the maxle for it to round. The end of the cut out you use to tighten is fine, but the other side is almost ruined to the point I cant use it. 12mm Thru axles are defo the way forward. Have them on my stumpy and love them.
Posted : 14/10/2012 3:27 pm
FWIW I've got a couple of maxle forks and they've both been used hundreds of times without problems. If you don't locate the lever properly against the face, you're likely to damage it- much like stripping a bolt head.
Posted : 14/10/2012 3:31 pm
So it's not looking good or a free replacement then. Maybe I am a it of a whimp when using it and haven't been locating it properly as north wind suggests.
Posted : 14/10/2012 3:48 pm
Yep mine has done the same
Posted : 14/10/2012 3:51 pm
