max tyre size on a ...
[Closed] max tyre size on a 719
 Earl
[#1695487]
Is a 2.4 mountain king or rubber queen out of the question?
Posted : 11/06/2010 1:41 pm
Nah - I've had 2.5s on there - ghetto tubeless at low pressures and they survived the Mega. They are better on a wider rim though
Posted : 11/06/2010 1:43 pm
 Earl
Would it be true to say that the higher the preasure the better they stay on the rim?
Posted : 11/06/2010 2:14 pm
I've a 2.35 Kenda Blue Groove up front and it's ok.
Posted : 11/06/2010 2:23 pm
tried one, felt a bit squirmy. Now running high roller 2.3 and they seem perfectly matched.
Posted : 11/06/2010 2:24 pm
Mavic site says:
ETRTO compatible size: 559 x 19
Recommended nipple length: 12 mm
Recommended rim tape: 559 x 20 x 0.6
Recommended tire widths: 1.50 to 2.30
Valve hole diameter: 8.5 mm, supplied with valve adapter
Posted : 11/06/2010 2:32 pm
Yeah, at low pressures they do roll around a bit - never had the tyre come off but handling felt a bit odd.
Posted : 11/06/2010 2:34 pm
These tyres are completely different sizes (MK << RQ)
I would imagin that a 2.4" MK would be fine, but a 2.4" RQ is probably a bit too big.
I have used 2.35" Kendas no probs though.
Posted : 11/06/2010 2:58 pm
i would just stick with 26" tyres if i were you.
HTH
Posted : 11/06/2010 3:31 pm
I've had 2.4 MK at about 30-ish psi on a 717. and it wasn't too bad squirm-wise. should be OK on a 719
Posted : 11/06/2010 3:35 pm
 Earl
Thanks
Posted : 11/06/2010 3:44 pm
Will a 2.4" RQ fit in yer frame, they're ****in hooge
Posted : 11/06/2010 3:49 pm
