I can't find the max rotor size on the Fox site - will a 203mm rotor be ok or is the max size 185mm (recommended) - I suspect 205mm rotor is max size recommended but can't find anything to check before I order up the brakes...
Thanks.
Taken from the Fox website
What is the maximum size disc rotor I can put on my fork?
32 & 36mm forks are designed to use disc rotors with an outside diameter of 160-205mm. 40 models are designed to use rotors with an outside diameter of 200-225mm.
Thanks...I spent a half hour this morning on that site and couldn't see that...I'll go clean my glasses!
It's well hidden in the FAQ section
I can't access the FAQ's just now which is probably why I didn't find it...that and probably needing my eyes tested! Thanks.
