Max PSI rating on H...
[Closed] Max PSI rating on Hope Flow 29er Rims? why?
[#6065461]
Noticed the psi max rating pressures for 4 different widths of tyres on the side of rims.
Do people stick to them? Does it matter?
Posted : 26/03/2014 8:45 am
Mavic also have a max psi chart on their rims.
You can ignore the Stans table if you are using tubes
Posted : 26/03/2014 9:09 am
 DrP
Having had a tyre explode off my flow rim at about 60psi, deafening me and covering me in wheel gunk, I can confirm that if the 'max PSI 60' sticker is there, I'd believe it...
DrP
Posted : 26/03/2014 9:11 am
Not if I'm running with tubes thou? That's ok then. 🙂
Posted : 26/03/2014 9:22 am
Don't think I've ever put more than 40-45psi in a tubeless MTB tyre and that was only to get it seated. A big tyre on a wider rim is a lot of square inches.
Posted : 26/03/2014 9:59 am
