Max heart rate on d...
[Closed] Max heart rate on decents
[#6953577]
So I think I'm reasonably fit, from an xc background but started racing enduros.
I'm constantly maxing our my HR on the downs. This seam right? I do like pinning it 🙂
Posted : 24/03/2015 12:47 pm
💡 coz ur scared innit 😉
Posted : 24/03/2015 12:48 pm
There may be an element of that 🙂
Posted : 24/03/2015 12:49 pm
I know what you mean, I hit a new record HR of 186bpm for me on stage 3 of the PMBA Enduro at Gisburn earlier this month!!
Shows what b*llocks the 220 - your age calculation is, that only "allows" me a max HR of 171 😳
Posted : 24/03/2015 12:56 pm
Could be interference from your clothing flapping about. My HR strap used to go nuts on the downhills with static from a synthetic jersey I wore. Doesn't happen with my other jerseys for some reason.
Posted : 24/03/2015 1:44 pm
The race was quite sticky and pedally in spots though.
My Max hr was 182 on stage 2 and a bit less on stage 3.
Posted : 24/03/2015 2:10 pm
It will more than likely be a synthetic jersey flapping/rubbing causing interference.
I wear cotton or wool for a more accurate reading.
Posted : 24/03/2015 2:18 pm
@mikeep - I have ridden with a few people using monitors who have said their max heart rate on the downs is pretty close to that on the climbs
Posted : 24/03/2015 2:25 pm
I rode a couple of days at Afan at the weekend and my max HR was on the Blade downhill to Glyncorrig - by 1bpm so I don't think it was due to loose jersey etc. I have previously had big peaks in hr which I am now sure was down to glitches in the belt - 220 minus age works spot on for me.
Posted : 24/03/2015 2:27 pm
yep. 2-3 minutes of sprinty anaerobic exertion, mixed in with a dose of speed/fear and forgetting to breath will pretty much max out my HR....
Posted : 24/03/2015 2:29 pm
Yeah, I think some of it is forgetting to breath (and blink). Maybe I should practice some relaxation techniques..........ohhhmmmmmmm........
Posted : 24/03/2015 2:34 pm
its where i always get my max HR, always has been and i don't race. its not being scared or anything else, you just use a lot more muscles moving the bike around therefore the old ticker has to work a lot harder and mostly the muscles are being used anaerobically.
Posted : 24/03/2015 2:51 pm
My HR is always higher on the descents than the climbs, not by loads, but always higher.
I enjoy the descents and trying to go as fast as I can , I dont care about the climbs, I'll get to the top in my own time.
Posted : 24/03/2015 2:55 pm
Same as Julians. My max HR will usually be on the downs. Going up I have a steady'ish high HR, but peaking on the downs
Posted : 24/03/2015 3:04 pm
