Mavic XM819 rims
[Closed] Mavic XM819 rims
[#1118651]
I'm after some new wheels and was recommended Mavic XM819's rather than 719 rims on the chosen Hope Pro 2 hubs.
My concern is that i just bought 2 pairs of new tyres (£120), the Mavic XM819 rims are UST, can i still use tubes and tyres with the 819's?? I did read that some people experienced pinch flats.
Posted : 10/12/2009 5:07 pm
Course you can use them, although you'll have to use Presta tubes, and some tyres are a nightmare to get on and off (anything 2bliss in my experience).
Just sold my Pro2/819 set to raise funds, but wouldnt hesitate to get another.
EDIT: You will experience more pinch flats obviously, as you cant get them tubeless, but, no worse than any other tyre. I think its just after going tubeless and not having them, it's hard to accept them again.
Posted : 10/12/2009 5:11 pm
Yup. Running mine tubed just now but as Swift says tubed tyres can be a nightmare so invest in long strong tyre levers.
Posted : 10/12/2009 5:13 pm
Also ive got a few sets of tubeless tyres ill be sticking on later cheap if youre interested?
Posted : 10/12/2009 5:14 pm
Ok...Im running Schwalbe 2.1 Racing ralphs in the dry and 2.25 Nobby Nics during the winter... (I like fat tyres)
Are these going to be a bitch to get on and off? I've never needed a tyre lever to get these off so far.
Is there a lot of difference in strength between 719's and 819's?
Cheers...
Posted : 10/12/2009 5:20 pm
Couldnt tell you, i ran 2.25 RR/NN combo on mine but the tubeless versions. They need no levers to get on or off, and inflate first time, every time. Now moved them on to my pro2/flow wheels.
ANd 2.25 isnt exactly fat? Mine have a much nicer profile on the flows than when they were on the 819s.
Posted : 10/12/2009 5:24 pm
2.25 is a dam sight fatter than my previous 1.95 speziallized tires...
Posted : 10/12/2009 5:27 pm
 br
I've a few wheels with 819's, run anything from 1.9's to 2.3's, although 2.0/2.1's feel best.
I run all mine tubeless, but use normal and/or UST and/or TubelessReady tyres with Stans liquid.
You can run tubes, but if you are gong to then get a cheaper rim, rather than 819's.
Posted : 10/12/2009 5:48 pm
I have a 719 and run a tubeless kit with it (singular - I've got my old 717 up front).
Is the 819 a similar width? How about weight? I know the bare 819 rim is ever so slightly lighter, but what about the nipple fixings?
Posted : 10/12/2009 10:48 pm
