mavic xm 719 or xm ...
[Closed] mavic xm 719 or xm 819
[#4597436]
Will be going tubeless with it but anyone got any experience of the 8 over the 7? Only 10g in the rim but I'm guessing I won't need nipples in the 8.
Posted : 26/11/2012 10:16 pm
819 if you will be running UST tubeless, 719 if you use a conversion kit like Stan's.
819's use an insert that you push the nipple through and then screw into the rim. Nipple then connects to spoke in usual way.
Posted : 26/11/2012 10:20 pm
Well actually you drop the insert over the spoke first, screw the nipple on and then screw insert into rim!
Posted : 26/11/2012 10:21 pm
The XM719 isn't tubeless/UST but you could still convert using rimstrips. The XM819 is proper UST but you do still need nipples; they are retained by the threaded eyelets; I've built a couple of sets of wheels using XM819's and it's a bit if a faff but okay once you get going. I've been using ZTR rims for a few years now.
Cheers have you run them?
Posted : 26/11/2012 10:22 pm
The inserts for the XM819's are made from one of the softest metals ever and are very easy to damage when tightening up, even with the proper tool.
Posted : 26/11/2012 10:23 pm
819 are a bit of a faff to build (do everything on the wrong side because of the threaded eyelets), and TBH they're a 'bit' heafty, but they're nice easy UST rims
Posted : 26/11/2012 10:24 pm
mikewsmith - Member
The 450g claimed weight for the 819 is crooked, it doesn't include the eyelets. The real, ready-to-build weight is 507g.
Posted : 26/11/2012 10:25 pm
Coming from ex721's I'd call neither heafty. May just got for the simple build on the 719. Looked at ztr rims but non seem to have eyelets and seen some split ones after heavy use.
Posted : 26/11/2012 10:26 pm
People fixate on the eyelets thing a bit but then, I've seen an awful lot of 721s crack around the eyelet. I don't think Stans give you quite the long-term durability of Mavic but then there's a decent chance you won't be using the long term lifespan, if something nasty happens to the wheel before that.
If I wanted something to do the job a 719's designed for, but tubeless, I'd get a Crest or an Arch tbh, Mavic wouldn't get a look in. My 819s are fine, perfectly capable, but it's an ancient design and it shows.
Posted : 26/11/2012 10:50 pm
I've found tubeless and UST tyres easier to mount on Flows and Crests than I ever did on 819's! Building a 29er over the next month or so, and that'll be having Arch EX's.
Posted : 26/11/2012 10:59 pm
I'll take another look at the ztr in the shop this week. 719 is still o the list as a tougher option. Crest looks a it too light weight for me. Going to run between my heckler and 150mm ht.
Posted : 26/11/2012 11:01 pm
