Mavic XA elite whee...
[Closed] Mavic XA elite wheels
https://www.flickr.com/gp/160633100@N04/38fN4e
Posted : 08/09/2018 12:18 pm
Well I stuck my Crossmax Elites on.  No pinging on the obligatory garden test ride, tyres straight up tubeless.  Together with the quaxar rotors its taken 270g off - about what I expected which was 200g from the wheels and 70 from the rotors.
[url= https://farm2.staticflickr.com/1867/44550397981_2d2e3b41fa_z.jp g" target="_blank">https://farm2.staticflickr.com/1867/44550397981_2d2e3b41fa_z.jp g"/> [/img][/url][url= https://flic.kr/p/2aSLrd2 ]2018-09-08_01-56-44[/url]
Its a lot of red but seems to work 🙂
I won't be able to ride it for a week or so, so I'll find out if they'll fall to pieces then.
Posted : 08/09/2018 3:36 pm
Looks sweet mate, I’m sure your wheels will fine 🤘
Posted : 08/09/2018 7:26 pm
@Kryton57
The wheels look spot on! I've literally just ordered the Spark RC 900 Team and was wondering how heavy the standard wheels are?
Thinking I'll put my SC Reserve 27s on it and use the Scott wheels to sell on my Hightower.
Posted : 09/09/2018 7:29 pm
They are about 1950g iirc.
They are robust being dtswiss internals, I’m keeping them for winter and these for events
Posted : 09/09/2018 8:26 pm
Ah they are pretty decent, if a little heavy then?  Good to know 🙂
Posted : 10/09/2018 11:55 pm
Just received some xa elites 29er boost. Front came with some boost adapters attached with a little grub screw.
Rear boost adapters were in a little bag and I just pressed them on. Seems to work but is that it? I can't find instructions in the box or online.
Posted : 12/09/2018 11:24 am
I just got some torque adaptors
what size is the grub screw, I don think I have a hex key small enough
Posted : 12/09/2018 10:43 pm
Not sure as they were already installed, but looks tiny.
Posted : 13/09/2018 9:08 am
 Alex
I’ve just bought (from Wiggle) the XA Carbons. Huge reduction on list - I assume - due to new wider ones coming out. As i only want to run 2,3/2.4 max on this bike I’m very happy to have picked up the wheels/tyres/tubeless kit for £580.
Replaced a set of heavy DT Rims/Hope Pro4/Maxxis WT wheels. 2lbs lighter! The tyres tho will be coming off when it gets wet. They amusingly slide-y. Wheels are fantastic quality tho, ride really nicely up and down and I like the whole ‘wheel system’ thing where you get valves/sealant/etc.
Posted : 15/09/2018 9:11 am
Saw the carbons were cheap, sadly, £580 not cheap enough for me right now !
Posted : 15/09/2018 9:15 am
 Alex
Yeah cheap is a comparative term 😉 Just been for a second ride on them - now tubeless - and they do make the same trails more fun up and down. Whether that’s £580 worth of fun would be a more difficult calculation!
My last set of Mavix wheels were some SL’s. Brilliant but fragile and the freehub needed love on a weekly basis. These seem significantly more robust/less silly spoked. We’ll see how they get on through the winter.
Posted : 15/09/2018 1:09 pm
How is the bargain winter bike then Alex? 😉
Posted : 15/09/2018 3:03 pm
 Alex
Bargain-tastic. I’d go as far as to say ‘cost neutral’. Although not if challenged to provide empirical evidence 😄
Posted : 15/09/2018 6:08 pm
Got some riding in and xa elites are great so far, seem tough enough & even survived getting a bit of air (followed by my usual cased landing)
They are much lighter & faster pick up & spin up than my old wheels, so bikes feeling much more agile.
Went up tubeless very easy.
Only grumble is that the torque caps are just held on with a rubber seal, rather than grub screw on 15mm caps.  Luckily they are a pukey lime green so easy to find in the mud when they fall off fitting the wheel.
Posted : 01/10/2018 1:48 pm
Resurrecting as these wheels are cheap again at CRC.
What's the consensus? A good buy? Strong enough for a heavy rider riding local trails?
Posted : 26/03/2019 8:49 pm
 Alex
Not used mine that much but took them on a very rocky ride ride Llangollen and they felt perfectly stiff. Running 2.35s on mine and that’s a good shape on the rims. Probably wouldn’t want to go much bigger as they are only 26mm internal. I’m 77kg so not exactly heavy. I do think there is a weight limit on the carbon ones?
Anyway so far so good, but as I say not too much use through the winter.
Posted : 27/03/2019 9:47 am
Thanks. Other option is to get my old Pro2 hubs rebuilt into something 27.5.
Posted : 27/03/2019 10:01 pm
Amazing wheels at the prices CRC have been selling them, but I try to keep mine for less rocky trails as they can go out of true easier than a lot of wheels.
Posted : 27/03/2019 10:15 pm
mine are still going fine, Im heavy & clumsy, but still true
ill know for sure after WGES at Afan this weekend
Posted : 08/04/2019 5:25 pm
Very happy with my Crossmax Elites, 650b boost version. Tyres are definitely summery light, some others are on order, but that's not to say they aren't good for the intended purpose.
I haven't put many miles on them, and I right pretty light too, but they feel very well put together.
Mine came with tubes installed, but with every thing included to go tubeless. Set-up to tubeless was a doddle though, no faffing around. Just needed to pop out the tubes, in with the T/L valves and the Mavic juice, then just pumped them with a track pump. I felt almost dissatisfied that it was all so easy, no heroic tale of hours of messing around.
Posted : 09/04/2019 2:57 am
yup they survived rocky afan
loving them now tbh!
Posted : 17/04/2019 3:14 pm
Page 2 / 2
