mavic wheelset
[Closed] mavic wheelset
[#1576492]
just got home with a set of mavic crossmax wheels i picked up of the forum classifieds. very happy just what i wanted. they have a system for securing the disc to the hub that involves a removeable gadey the disc sits on and then you tighten on a lock ring? never come across this before. anyone any experience, good or bad? looks to be secure, should i lock tight the lock ring? any pitfalls?
thanks
Posted : 05/05/2010 4:59 pm
shimano centrelock?
Posted : 05/05/2010 5:00 pm
Sounds like it. It makes changing rotors much more simple and does away with bolts, rotors are slightly more expensive and heavier, you can get adapters to run normal 6 bolt discs, Superstar are the cheapest.
Posted : 05/05/2010 5:01 pm
it happily takes my original 6 bolt hope discs, you just pop them onto the six studs and then tighten up the lock ring?? not shimano jobbies.... these are new 2010 wheels and i guess its an "inovation" from Mavic
Posted : 05/05/2010 5:04 pm
Nope, they've just already got Centrelock adapters!
Posted : 05/05/2010 5:07 pm
njee20, so what do you do if you dont want to use the centre lock method? there is nowhere to "bolt" the disc to in the usual way?
Posted : 05/05/2010 5:13 pm
have just re-read your previous post...oops!! so i cant just use my existing disc's? bummer
Posted : 05/05/2010 5:14 pm
Of course you can, if they fit, then great.
Centre Lock hub:
Centre Lock Rotor:
Centre Lock adapter:
If you have the 4 'tabs' for the bolt holes, then just use your current 6 bolt rotors.
Posted : 05/05/2010 5:18 pm
you must think i am a spanner?? now i see that it came with a six bolt adapter and the disc sits on perfect? sometimes you just need a nudge in the right direction.... thanks
Posted : 05/05/2010 5:21 pm
