Mavic Crossroc rear...
[Closed] Mavic Crossroc rear hub wobble - fixed.
[#6057308]
Got some new 650b Crossroc's and noticed that the rear wheel had play in the hub when fully tightened. Took the dust cap off the disc side of the hub and behind the axle circlip the bevelled washer had a spring clip around it's edge. This clip should be behind the bevelled washer to tighten the hub assembly and once I pushed it in place and refitted the wheel everything is good.
These are brand new wheels and never stripped before so this error in assembly was made at the factory. I just thought I'd mention it in case anyone else has the same issues as it's an easy fix.
Posted : 22/03/2014 4:51 pm
