First rear wheel in France now done the same on a lap of cwmcarn. Anyone else. Had this problem, seems to be drive said all the time.
Are you a larger gentlemen by any chance?
I ain't small and mine have been fine with some lairy and unskilled riding.
Tell us what happened to it.
What happened to it exactly?
What happened, mines have been spot on so far
He was riding around Cwmcarn and the spoke broke... 💡
I had the main axle shear off on the rear wheel after a day at aston hill, have since upgraded with a mavic extreme axle which makes it a bolt on wheel now. also now have a bent spoke after casing a landing very hard.
I'd say the problem here is casing the landing 😀
What year are they as there is an upgrade available for some rear wheels. fitted one Yesterday.
i am on the larger side but iv been told theres no weight limit on these.
i snapped 3 in france and 1 on the weekend. all drive side and at the bottom near the hub.
You don't seem to make much sense. What have you broken? If it is a spoke then get over it, this stuff happens.
I_ache get over it???
it doesnt happy that much, im just trying to find out if others have the same problem
Is it a spoke then?
These things happen, it's not as if the bearings have collapsed or the hub has cracked in half.
Maybe it's a bad build, maybe it's bad luck or maybe your just clumsy. I would get my lbs to loosen of and re-tension all the spokes.
[url= http://www.247cycleshop.com/shop/category_10/Mavic-Mountain-Bike-Wheel-Spokes.html?sessid=JFHHpDo4aXoTOYzgTPVmppKrU2s8L3t5GFcxReaslo9yDoapApZSUTm0iJllTKK8&shop_param=cid%3D%26 ]Mavic MTB spokes[/url]I stock a range of spokes for the SX if you get stuck.
Both the grey & black versions.
Neil
