Mavic Crossmax SX a...
[Closed] Mavic Crossmax SX axle/free hub help.
[#5234719]
Ill let the picture do the talking first. [img] [/img]
Just checked my bike over after yesterday's adventures and found a wobbly wheel,removed wheel from bike and found what you see above.
the wheel is a 2012 crossmax sx, the hub and bearings are fine, its just the axle thats sheared off.
So what do i need to order? does the axle come with the freehub, is it even called an axle?
Thanks
Posted : 10/06/2013 9:57 pm
all part numbers listed here.note number and contact mavic uk service centre or any dealer they can order you part,takes about a week though.
[url= http://www.tech-mavic.com/tech-mavic/technical_manual/data/docs/themes/2_16.pdf ]mavic tech[/url]
Posted : 10/06/2013 10:47 pm
Had the same issue last month, trawl the forums, it's common.
You could replace with an mavic extreme axle if it goes again.
Posted : 10/06/2013 11:12 pm
its done well by the sounds of it., over a year of maintenence free riding, the final straw was on at aston hill on sunday. Cheers for the info
Posted : 11/06/2013 5:30 am
