Mavic Crossmax Endu...
[Closed] Mavic Crossmax Enduro Freehub question...
[#188511]
When holding the rear wheel on my Mavic Crossmax Enduro the cog spins in both directions and obviously when I try to pedal nothing happens as it is not engaging. I'm hoping that this means that all I need to do is service the freehub or is it a wee bit more complicated than that? Anyone got a link on how to do this as I can't find it on Mavic site?
Posted : 03/01/2009 9:24 am
unscrew the end caps, remove the axle, pull off the freehub body, and check the two internal pawl/spring units. you've either shredded them, lost the springs or fouled them with crap.
Should be a ten minute job if you haven't trashed the body with huge G-out landings.
Posted : 03/01/2009 10:48 am
